My website, the builder, everything is down. Please Help
If you added this code through your embed tag, you can disable all embeds so you can remove or fix your embed.
You can open your builder with: yourdomain.com/builder?embed=off
If you dont manage to fix it, send me your website url and I will take a look
The solution didn’t work
If you have error with embed, then use ?embed=off, however for plugins use ?plugins=off and you should be able to access your website and fix your code.
If you wish to extend variable functions, use following code
mdFunctions.ItemsAdd({
parameters: {
length: {type: 'INPUT', 'value': 120},
description: 'Cut value to max length.',
group: 'String',
function: function(data, value, length)
if (value.length > length)
return value.substring(0, length) + '...';
return value;
I did not test the code, but should work, test it.
Works like a charm !
