Forms to airtable and airtable local vars
Hey divhunt team,
got two questions:
  1. Is it possible to push forms data to my airtable?
  2. Can I store fetched airtable data in local vars somehow (getting all airtable data in a nice Jason would be a great way)?
I’m enjoying the ride so far, already built great stuff with divhunt.
Thanks in advance, you guys rock :v:
What I know: You can use webhooks to get it to make/zapier > airtable. I’m not sure about other ways, but I’m looking forward to hearing about them.
Thanks @petrbilek,
yes I saw the webhooks approach. I dug a lil deeper and found out about automations in airtable:
I’ll try to make it work by the same way as the make implementation works.
When successful, I’ll post it here.
Constantly getting this in the console:
Access to fetch at 'https://hooks.airtable.com/workflows/v1/genericWebhook/appp42XoFheD5uWz5/wfldCk2DpT8BBaHmI/xxxx from origin ‘https://xxxx.divhunt.website
has been blocked by CORS policy: Response to preflight request doesn’t pass access control check:
No ‘Access-Control-Allow-Origin’ header is present on the requested resource. If an opaque response serves your needs, set the request’s mode to ‘no-cors’ to fetch the resource with CORS disabled.
Any ideas how to avoid this nasty error?
@dejan could your recent fix for gfonts also fix this CORS problem? Thanks in advance
