Menu anchor did not work one redirect to the next page section
Hello, small bug here, not sure how to solve the issue:
Here is the link: Ochrana osobích údajů na webu | Věra Labajová (divhunt.art)
Once you hit the menu, you should go to the homepage section as an anchor link. But the anchor is not working properly.
You can try to create JS file which is being loaded onPageReady, and use this code below to scroll to anchor.
    let anchor = window.location.hash;
    if(anchor) {
        var targetElement = $(anchor);
        if(targetElement.length) {
            $('html, body').animate({
                scrollTop: targetElement.offset().top
            }, 1000);
Thank you, Will try it.
Just want to thank you! Works like charm. Basically first client site ready to convert :slight_smile:
