Not able to access builder of a project, It is completely blank. After so many refresh still encountering the same issue. Other project have not this issue yet, attaching the website link.
Haven’t resolved this issue yet, kindly please help me out.
I’m having the same issue(!) :-/
@Pakic Still facing the issue, It would be really appreciated if you please take look into.
you broke something in your creator code.
You can use link below to open builder without running creator code until you fix a code error causing builder to crash. I see you have 2 custom plugins there.
https://alprav-design-temp-v1.divhunt.art/builder?creator=off
What is your website url?
Hi! Thanks! It’s: www.protectingveil.com
You have two A records connected to your domain.
You need to have only divhunt DNS A record connected and CNAME.
If you can’t figure it out, let me know
Thanks again! So…I got rid of two extra A records(!) There’s now only one A record and one CNAME record. (I do have other records: MX and TXT records - which, as I understand it, provide the connection for my email fowarding?) But…the site is still having problems(!) :-/
It didn’t propagated yet.
On this website you can see theres still 2 IP’s on A record.
Maybe try to set lower TTL on your DNS domain provider side? What is your domain provider?
NameSilo! Just switched it to the lowest TTL possible (3600)…
The TTL is set to 3600 (one hour)…but it has been 2+ hours(!) Is there anything else we can do?
Seems to be good now? I just checked?
I still see the wrong one (75.98.175.76) in Russia, France, Spain. That said…Builder and Admin are now opening into a blank white screen (still a problem…just a different problem!) rather than Error Page that was being generated. So…perhaps there’s a new problem?
Try force login to builder with Protecting Veil - Temporary | Divhunt Login
Thank you so much for helping me out. I’ve removed those, now it works fine. Have a suggestion in mind @Pakic it would be great if we have a plugin for adding Google Tag manager or Google Analytics and Custom cursor in Divhunt builder.
