Hi, I have put my information and styled my rich text info inmy cms collection. When it appeared on my web page as a variable, the styling has nearly all disappeared apart from what I manually added as css ie color of headers. You should not have to style twice the rich text info so there is a bug. Please fix asap.
add some photos and url
as the slug cms does not work and await on you for help on that, here is what I get as the page https://project-3530972.divhunt.art/blog/null
name of slug is: Car window tinting - Elevate Your Vehicle’s Style and Functionality
the above could help you get the page until the slug issue is fixed
Hi any chance to get this fixed before I publish my site. thanks
Hi fixed the slug issue so the page is https://project-3530972.divhunt.art/blog/car-window-tinting-elevate-your-vehicle-s-style-and-functionality
What needs to be fixed is the rich text issue
Hi noticed that my table of content is showing up however not working and the line table of content appears at the bottom which I did not write. Furthermore, I can no longer change my button component on a page as it will modify the main component. The share social also do not work even thought they are set up following your videos. Please help fix this
Hi DIVHUNT any chance to finally get an answer on this issue with the cms and rich text. I really need this fix asap so I can publish my site
Hi, your social share links are working, for rich text, you need to style it on the front-end in a way you like. Theres a tutorial covering all rich-text possibilities. Its not coming with pre-styled elements.
Also every plugin that you plan to use has a video tutorial here: Unlock new features with community-made plugins | Divhunt
And many more tutorials you can find on our youtube channel that can help you.
Such as use of CMS instead of creating 50 same pages inside of builder with different title. CMS can help you with that, same way as you are writing blogs, you can create galleries, using CMS and one page-template.
Hi I have followed your videos about cms and now will need it to work on my pages which it does not as per info sent above. So please help fix this asap as this my issue.
I am not sure that understand what is not working?
Theres are your blogs, and they work:
And when you access them from your blog, they work
No. As per my numerous messages the styling does not work in the rich text part so please help fix this as I cannot edit it either on the webpage.
Just tried it on your blog page, and I can confirm that styling works correctly, same as in this video:
I applied some default stylings to your rich text
Hi I have seen your changes. Why is the cms rich text not applying directly the same styling in the blog page? Would this not be more convenient? We would only have to do the styling once as customers? Anyway, thanks for your help on this occasion.
In that case you would be very limited what you can do. Our rich text is not powerful enough for you to create custom stlyings, like colors of headings, spacings between things and much more. This way, we give you full control to use our builder to style rich text (Which is just a block of nested elements, such as h2, paragraphs, images, etc).
I see… Thank you for the explanation.
One last unanswered question, how to have all the tabs closed in the accordion as imputing the value 0 does not work.
Try using some random number like 999 instead of 0? We will create native checkbox option for that, until then, I think this could help
