One important thing about SEO. If you are checking your canonicals or meta descriptions, or anything else in terms of SEO. Including sitemap, always check it from incognito tab, when you are logged in, Divhunt is not returning you correct data for now.
@Pakic: This is an underrated feature, to say the least
This functionality is super-useful in almost any field in Divhunt and with a little bit of planning (and practice) you can combine static- and dynamic data anywhere you want:
Links
Meta titles
Descriptions
Social share buttons
Attributes
Dynamic content in running text
Placeholder texts in forms
etc, etc.
And if you use REST data this data is also available in the same way (almost). It can look a little daunting to “code” at first, but it will change how you handle data when you get the hang of it.
Divhunt has built a truly amazing tool for us to use, and I think we’ve only seen the start of it.
As said, learn this and it will be your superpower when developing your sites
