I can’t figure out how to filter projects per category in Our Work section:
I just noticed that they haven’t implemented it in the original template as well. Whatever you click it just shows all blog posts.
I couldn’t find a relevant topic or video tutorial, so please point me in the right direction if you have already explained it somewhere.
I’ll try this approach. The thing is, in other cases where they used plugins for Codify, the plugin itself was already at least partially set up. In this case, it wasn’t even installed. I thought they used a different route to achieve the same result, and I was afraid of messing something up.
Also, they used Tabs plugin in this case, so I’m not sure how two plugins should work together.
Look at my gallery and filtering option Projekty i Realizacje Ogrodów wykonane przez nas.
I did it with the plugin I posted above.
I replaced the Tabs plugin with a simple filter, but it still doesn’t work as intended. The tutorial doesn’t cover CMS items, which what I’m working with.
