Hi I have a loop with 5 links on my navbar however in the component the loop numbers s do not appear in the dropdown as it does not show so I cannot link them to anything however they appear each pages of my project. Can you please help as my site is live and need urgent assistance.
Can you not just click on each button individually in the builder and edit it directly, instead of using the drop-down? Also, make sure you’re editing the source component, not an instance of the component.
Well if I click on each button when I am in component I go back to the instance so not a good idea. Why are the loop not showing in the component in a drop down as they should? this is the issue. I do not feel like going to each page and change the buttons links as this would take a lot of time and what would be the point of the component…how can this be fixed
No, I mean go to the original component and change each link there. In your builder click on components (top left) and select the navbar. Then, you should be able to click each button with your mouse (as opposed to on the layers on the left) and edit the link, no?
Hi as you can see the navbar component is there however does not show up but you can change the info on the layer panel and as you can see the info are correct but not reflected in navbar on the site. I guess there is a bigger issue there. Please help
I have another issue with the hero section. If I want to change the background picture ie contain or cover of the instance it affects the components as they all. can you help fix this too
