Hi Divhunt team,
My custom domain was working for the pas week however now it is timing out. What can I do to diagnose the issue.
Many thanks
Hi Divhunt team,
Many thanks
Could you share your domain name?
the domain: otspacking.com
Seems to be working normally for me?
Everything seems good.
Strange, I can access it with my VPN on but not without
Hmm, where are you from?
I live in Singapore, tried both on wifi and mobile across 2 devices but was only able to access the site via vpn to the US
Please allow us some time to investigate.
Thanks, let me know if you have any updates ![]()
Hi @dejan,
Taking a look again
Using https://downforeveryoneorjustme.com/otspacking.com it shows as down for me.
And my GA shows a suspicious drop for yesterday
Appreciate your further assistance
Hi @Mrchiwi
I am still waiting for answers from technical guys, not much I can do.
Let’s do this, replace the IP to 151.139.87.15 as temporary solution, no downtime will be present. It should work until we fix the issue with our global IP.
Thanks, works now as a temp solution!
Can you ping now our main IP: 185.85.196.60 (from your pc terminal: ping 185.85.196.60)?
Ping statistics for 185.85.196.60:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 41ms, Maximum = 41ms, Average = 41ms
Could you now revert back to our main IP: 185.85.196.60 and test if it works, since pinging works, seems like issue is fixed. Please let me know once you do and if website works for you.
Ive reverted back but now it times out
Thanks for letting me know! Please allow us some time, we are working on a solution and I’ll let you know as soon as it’s ready and fully working.
Until then, please use the solution I provided as for now.
Please use the following IP address: 34.102.250.126 and let me know if everything works properly now. In case something is wrong, please revert back to: 151.139.87.15
