Hi! How can I add/host PDF Documents on my Divhunt Website?
@dejan We also need this, how can we have a PDF hosted on our website?
Hello I would require an answer to this question as I have pdf files which needs to uploaded and linked to a button. I have created a folder cannot add file to it. Can you please help with this. thanks
Hi would really like an answer to this question.
Hi there ! I am relatively new to Divhunt, but have you tried selecting “Documents” first in the media uploading window before actually uploading the file?
Then also, have you tried binding the link through page > data variables? Mine seems to work fine.
hope this helps,
Andrew.
thank you for your answer. You seem to be more advanced than I am with the variables.
@divq thank you - certainly a compliment I didn’t expect. If however you are expecting at a later stage an “array” of uploads or to allow multiple files in other words - that is certainly a learning curve I’m yet to wrap my head in. But hopefully others can chime in. Sincerely, Andrew.
