Hello Team,
How can I get a FAQ styling like this in the attached
You can drag & drop default Accordions, and then style it. (make sure you’ve installed plugin).
Can you guide me as to what style setting I need to change to get the desired results
Team pls I am not sure how to achieve this output…tried still no luck.
Please assist
Hey Sania, this is just simple CSS and HTML.
Drop shadow, white background, rounded corners… You need to know CSS and a bit of HTML to achieve this.
You can also check with Chrome and Dev Mode the CSS styles that are applied to the website you want to copy from.
