I want to use Airtable as the CMS for my blogs - what’s the process for setting this up?
After you setup your Blog in Airtable, follow next steps:
Step 1: Install Rest API application in Divhunt.
You can do this by going to admin of your project and then click browse applications. Find “Rest” and click Install.
You can also access it by going to your_domain.com/admin/applications
Step 2: Get your access token from Airtable & connect it to Divhunt
Check Airtable guide on how to get an access token for your tables.
After you got a token, go to Rest application inside of Divhunt, then in sidebar under ‘Integartions’, you can go to ‘Airtable’.
Or you can just access it by going to url: your_domain.com/rest/airtable
Now, all you need to do is to paste your token in input field ‘API Key’ and you are all set.
Step 3: Your tables are now available to use in Divhunt builder.
Follow guide from this link in order to show Airtables on your website.
I integrated my website made in Divhunt with Airtable according to the instructions. I click on div block , next select source… and here the airtable data does not appear. What am I doing wrong?
I want the testimonials from my clients that I keep in the airtable to be posted on the website.
Now I understand, I had to publish the page…only then did the airtable source appear…
