I’ve designed a form and added the select field. On web, it’s not working as it should, but on mobile, the field pops up.
How can I make it look and work as every other dropdown field?
Is this set to be select with multi option checked?
Can you give me your website url
I did some changes, let me know if it is good enough. I applied plugin “Pretty Forms” on your form.
Thanks, it’s better.
I can’t see some of the values in the second “Select” dropdown
Can you show me how you fixed it. I’m trying to work on the values and I cant find the settings.
I’ll appreciate it @Pakic
