That ‘Structured Content’ is coming from Iframe. So it can’t be changed from Divhunts side.
Inside of that iframe you can find this, but I am not sure if you can’t edit it.
Anyway, it’s just a warning, not an error, so it will not have any impact on SEO as of my knowledge
Thank you very much, that pointed me in the right direction. I was able to add to the description via the CDN, I thought this was something that I was supposed to do on the site itself.
Since we are on the topic, is there a way to add custom metadata in general, to other html elements in Divhunt? Like for a regular mp4 video that is not in an iFrame, or any other element, if need be?
I’m not a Divhunt dev, but when alt text gets added to an image, within the element’s attributes (Advance>Attributes), a line gets added with the key=alt and then whatever description you want. Is that helpful?
Yes it is, thank you! I extrapolate from that that whenever I want to add a meta tag / data attribute to any element that I can do that there. Appreciate the help @Marc.
