How to move to my hosting?
I just have a question. If I create a website using Div Hunt. Can I host it on my Hosting server?.
If yes, what’s the process of it, and will I loose any plugins that are there?.
Also in which platforms it can be host?, will it be transferred as a directory or WordPress?. Thanks.
@Kuldeep
We are working on export functionality, however it will generate only static website HTML & CSS, with some of JS.
Most of plugins might not work as well are are built to work with Divhunt platform.
So exporting will be only good option to build HTML & CSS then export.
I just pointed my domain to the new nameservers and published again from the dashboard. Everything worked fine after a couple of minutes once the DNS finished updating.
What is your website url?
