How I should write code to display external READ(GET) api details to display on clicking a button.
That’s pretty advanced JS. I created some example with chat GPT, but you would need to adjust it to your needs ![]()
$(document).on('click', '#read-more', function() {
$.ajax({
url: 'YOUR_API_ENDPOINT', // Replace with your actual API endpoint
type: 'GET',
dataType: 'json', // Assuming the response is in JSON format
success: function(data) {
// Assuming 'data' is an array of objects with image, title, description, and url
data.forEach(item => {
var cardHtml = `
<div class="card">
<img src="${item.image}" alt="${item.title}" />
<div class="card-body">
<h5 class="card-title">${item.title}</h5>
<p class="card-text">${item.description}</p>
<a href="${item.url}" class="btn btn-primary">Read More</a>
</div>
</div>`;
$('.blog-grid').append(cardHtml);
error: function(xhr, status, error) {
// Handle errors here
console.log('Error: ' + error);
How to link this jscode to the respective button
