Hello Divhunt team,
I’ve been trying to implement an animated background effect in my hero section similar to what Calendly uses on their website (https://calendly.com/), but I’ve encountered multiple roadblocks despite trying several different approaches.
What I’m trying to achieve:
- A subtle, animated background with moving blue and purple gradient shapes/blobs in the hero section
- Similar to the flowing background effect seen on Calendly’s homepage
- The effect should appear behind the hero content without interfering with it
What I’ve tried so far (all unsuccessful):
- Embed Component Method
First, I tried adding an embed component to the hero section with this code:
<style>
.animated-bg {
position: absolute;
top: 0;
left: 0;
width: 100%;
height: 100%;
background: linear-gradient(-45deg, #6a5acd, #00bfff, #ff69b4, #00fa9a);
background-size: 400% 400%;
animation: gradientMove 15s ease infinite;
z-index: -1;
@keyframes gradientMove {
0% { background-position: 0% 50%; }
50% { background-position: 100% 50%; }
100% { background-position: 0% 50%; }
</style>
<div class="animated-bg"></div>
Result: The code appeared in the embed component but had no effect on the site.
- Custom Code Section Method
Next, I tried adding code to Site Settings > Custom Code in both Head End and Body Start sections:
In Head End:
<style>
@keyframes gradientBG {
.animated-bg {
position: absolute;
top: 0;
left: 0;
width: 100%;
height: 100%;
z-index: -1;
background: linear-gradient(-45deg, rgba(0, 119, 255, 0.7), rgba(143, 0, 255, 0.7), rgba(0, 194, 255, 0.7));
animation: gradientBG 15s ease infinite;
</style>
In Body Start:
<script>
window.addEventListener('load', function() {
const heroSection = document.querySelector('section');
if (heroSection) {
heroSection.classList.add('hero-section');
const animatedBg = document.createElement('div');
animatedBg.className = 'animated-bg';
heroSection.insertBefore(animatedBg, heroSection.firstChild);
</script>
Result: Nothing appeared in the hero section.
- Animated Blobs Method
I then tried creating animated, blurred shapes to mimic Calendly’s effect:
<style>
.blob-blue {
position: absolute;
top: -10%;
right: -10%;
width: 60%;
height: 60%;
background-color: #0077ff;
border-radius: 50%;
filter: blur(70px);
opacity: 0.7;
animation: moveBlob1 30s ease-in-out infinite;
z-index: -1;
.blob-purple {
position: absolute;
bottom: -20%;
left: -10%;
width: 70%;
height: 70%;
background-color: #8f00ff;
border-radius: 50%;
filter: blur(90px);
opacity: 0.6;
animation: moveBlob2 35s ease-in-out infinite;
z-index: -1;
@keyframes moveBlob1 {
0% { transform: translate(0, 0); }
50% { transform: translate(50px, -30px); }
100% { transform: translate(0, 0); }
@keyframes moveBlob2 {
50% { transform: translate(-50px, 50px); }
</style>
Result: Again, nothing showed up.
- Simple Test Case
To troubleshoot, I tried a very simple test case:
<style>
#animation-test {
position: fixed;
top: 10px;
left: 10px;
width: 30px;
height: 30px;
border: 2px solid black;
z-index: 9999;
animation: testAnimation 3s infinite;
@keyframes testAnimation {
0% { background-color: red; }
50% { background-color: blue; }
100% { background-color: red; }
</style>
With JavaScript:
<script>
document.addEventListener('DOMContentLoaded', function() {
var test = document.createElement('div');
test.id = 'animation-test';
document.body.appendChild(test);
</script>
Result: Interestingly, the test square DOES appear and animate correctly, showing that basic animations can work.
- Simple Blob Test
I then tried a single, simple blob alongside the test square:
.simple-blob {
position: fixed;
top: 50px;
left: 50px;
width: 200px;
height: 200px;
border-radius: 50%;
filter: blur(30px);
opacity: 0.7;
z-index: 9998;
Result: The blob briefly appeared but was static (no animation) and then disappeared when implementing more complex solutions.
Important note:
I was able to implement this exact same effect in just a few minutes using a standard IDE and web development tools. The CSS/JS code itself works perfectly in regular environments, so the issue seems to be specifically with how Divhunt processes or restricts custom code and animations.
Questions for the Divhunt team:
- Is there a recommended way to create animated background effects in Divhunt?
- Are there specific limitations on CSS animations or JavaScript DOM manipulation I should be aware of?
- Is there a native Divhunt component or feature I could use to achieve this effect?
- Could there be a specific setting in my project that’s preventing these animations from working?
Any guidance would be greatly appreciated as this effect is quite important for my project’s aesthetics.
Thank you!
