Issue with Hamburger menu
Inside the builder is look fine but not working in Live, adding extra padding that doesn’t even exist.
Site link: alpravdesign.com
Inside Builder
Live Site & Preview
event issue with the about option, if I click, it doesn’t disappear.
Please anyone is here? I’m facing this issue for so long
found an issue, so I guess when working with animations in CSS, which in your case is done through plugin “simple scroll animations”, it seems like css treats animate div as “position:relative”, so your absolute positioned menu gets attached to that div instead of body.
In your case I removed an animation from this navbar-component… Didnt find any better solutions
Thanks a lot @Pakic it has now fixed but if you kindly check the anchor scrolling inside the Hamburger menu it would be nice cause it’s not disappear after I select the about option.
