How to access another variable value in interable? In CMS, it is a relationship field, but I can’t get other data out of it. Only the ID of the collection is shown. Request for help.
Try to manually add function, not really sure how to make it, but probably have to manually write steps (if it’s possible) - just select Get(‘put variable name here’ manually’) till you get what you need.
NOT SURE IF WILL WORK BUT ITS WORTH CHECKLING.
Unfortunately, it doesn’t work. I have tried this and nothing ![]()
If it’s stuck in an array, have you tried index(‘0’) etc?
Unfortunately, but index 0 doesn’t help at all either. I think this is some kind of divhunt error
Hi, any news? Please help
When working with iterable inside of iterable try using unique key instead of leaving it on default of “value”
So here type custom key name if you didnt already. If you did, then I will to check it out ![]()
I’ve tried it this way before because I know you can’t give the same value. But when I used a different key, it didn’t show up in the options when configuring the div
I would like to ask for your help. Thank you
