I’m just starting so what programming do I need to learn to be able to use Divhunt effectively? Thanks
The builder itself is producing HTML & CSS for you, but if you want to master Divhunt, I would suggest learning JavaScript as well, since then you’ll be able to modify and extend Divhunt functionality and build plugins, literally anything.
Hi and welcome!
Check out some beginner tutorials for CSS and HTML as @dejan said. I don’t know JS (JavaScript), but it’s powerful af, so if you have time and resources, learn it. It will do wonders for your developement. You can learn tons and tons from YouTube
Good luck!
HTML / CSS /JS is a great start.
