Hi @Darko@dejan , for the cover parameter, can we provide a value from a variable?
For example, I’m displaying thumbnails of images associated to an article and I would like to setup the lightbox’s cover parameter with the variable which is the current image I’m clicking on.
Note: I use an iterable to access the images URLs (thumbnails & original image) from a Strapi table.
I feel like this feature could still use some more customisation options. For example; to be able to choose whether or not to show a white background around the image, to adjust the size of the image within the white background if you have one, choices for navigation via arrows or dots etc, the option to convert an entire section into one lightbox with all the images in that section automatically added to it and so on.
Are the features of the lightbox designed by the Divhunt team or is this plugin produced by an external team?
Oh, and it is customary behaviour to be able to press the escape key on desktop or back button on mobile to close the lightbox. If it’s okay, I will leave any other desirable features here in extra comments if I think of them…
It is also intuitive to use arrow keys on a computer keyboard to navigate through lightbox images within a group but this does not appear to be possible at the moment?
Also, when I created a “group” for images in a section, when you click on the first image in that section, it opens in lightbox as the last image on the thumbnail slider at the bottom of the images. I would expect it to open as the first image on the thumbnail slider and then to navigate to the right to view the other images in the group. Is this a bug or is there something I need to do differently to achieve this please? TY
Darko explained it in video that its really simple structure, in this case he just created a div, and inside of the div he put an image. And when he clicks that div, lightbox opens, since he applied lightbox that div, which is wrapper of an image.
Point is, you can apply lightbox to anything, you can create a button for example “Play Video” and apply lightbox to that, which will open a popup video, or whatever you set.
Thank you Pakic,
I got it. As a phtographer I am trying to recreate my website in divhunt. I was looking for a masonry gallery where i can set images in a row, and when someone clicks an image, a lightbox pops up. Is this possible?
But here the grid layout is not masonry. there are gaps when images are of different sizes…So this layout is not good for gallery items, especially for photographers… Is there any way to make it a masonry grid ?
One way that worked well was using a lightweight plugin or script that opens images in a clean overlay, no distractions. It’s kind of like how a digital picture frame shows photos perfectly without clutter—just the image, clear and front-and-center. Adding that kind of focus makes viewing your work way more enjoyable, especially for photography or any visual art.
I just used the onClick action to open a lightbox by linking it to a section and using a bit of visibility logic—it worked better than expected without needing extra code.
Weird, especially in terms of configurability – particularly for images and image galleries. You can’t really design or adjust it properly via settings or CSS. For example, I’d like the images to have no white border and to be larger, but that’s not configurable at all, and the images are relatively small. I’m also not exactly sure how responsive the whole thing is.
