I have a carousel with pictures of work by various artists. For the carousel image containing element I have used loops so that each one has the same styling, as it should be.
There are 10 artists and I would like to show 4 images from each one. Thiese numbers may go up in the future. So I want to make 40 carousel spots. But when I try to do that, it resets to 24 loops. Is that intended or a bug? If not a bug, why is there this artificial and extremely low limitation? I need to be able to use as many loops as I see fit for each use case I come accross, how can I achieve this in Divhunt?
