So I have a rest api that gets the index list on my main page:
{{url}}/api/jobs
I want users to filter for a category of jobs. My backend API (Strapi) has a filter feature:
{{url}}/api/jobs?filters[professional_field][$eq]=${properties->get('category')}
However, if the property value is empty or null, it filters everything and my filter doesnât work how I expect it to. Strapi wants the entire param removed if I donât filter by it. Is there a way to remove the query entirely if the value is falsy?
I would suggest duplicating the request, and then in builder you can have 2 sources set on 2 separate div elements, and using visibility conditions you can choose which one to call.
Apart from that, I donât see any other solutionâŚ
Strapi is open source, Iâll see if I can figure it out on the backend side.
Also maybe could work:
Instead of
To
?filters=${properties->get('category')}
Then in builder, send whole string as [professional_field][$eq]=something
Iâll let you know if I can figure it out.
If anyone comes upon this post in the future, I solved the problem using Strapi route middleware. I started with this blog post: Route-Based Middleware to Handle Default Population Query Logic
And modified ctx.query for my use case.
Alright @Dijan, I ran into a problem. I need the parameter values to be literally blank. However if I leave them blank in Divhunt, they output the string ânullâ
In postman this works great:
But this is what divhunt does in the REST API:
CURL Request Preview
curl --request GET âhttps://url.com/api/jobs?filters[$and][0][professional_field][$eqi]=null&filters[$and][1][location_option][$eqi]=null&filters[$and][2][$or][0][title][$containsi]=null&filters[$and][2][$or][1][descr][$containsi]=nullâ
âheader âAuthorization: Bearer XXXâ
Any ideas on the default value to get a literal empty string, instead of ânullâ?
Does it still say null if you put it like ${properties->get(âsearchâ, ââ)}?
I never responded to this, but no, the extra blank text parameter still leaves the query param value as ânullâ
Re-opening because I ran into a similar problem.
Setting Query parameters in the REST API
The properties Iâm referencing
The Curl
curl --request GET 'https://cuvijgvlafsivaekytkv.supabase.co/rest/v1/rpc/get_all_jobs?p_limit=null&p_offset=null
If I leave the query params empty, the whole param doesnât get included in the REST call, but it doesnât follow through if I leave it empty in the properties section. Can I get that behavior to follow through from the property variables so the string ânullâ doesnât show up?
