Menu isn't publishing links of nav items
website: oztinyhomes.au / tiny.divhunt.art
I’m editing the links to the various anchors in the main component of the navbar. Then the instances don’t seem to update the actual link but they do update the text if I change that. I had to manually alter the URL links.
In either case however, after publishing, the live site doesn’t show/link the expected URL’s.
Screen record of issue: Divhunt Instance Menu Issue
Still having this issue
Actually problem is not a component, its loop
If links are looped, they need all to be same type, so if homepage is type “page”… all other need to be type page, not regular links or anchors.
So in your case, I would suggest not using loop for all link… I mean you can use loop for 2nd, 3rd and 4th item, since they are same type
