Navigation undefined issue
I’m having issues connecting links from the dropdown navigation menu with pages.
I get “Undefined” message on preview and live page. I have connected the links with pages in the builder.
Seems that if you use a template, not everything comes out of the box. In case with Codify, the dropdown element didn’t have a Dropdown Wrap component activated in settings (Transform>Popup>Dropdown Wrap).
Hey, problem is that template is using popup plugin, and in settings they used on hover open “component” or “tag”.
Problem that we are having with this is when you do this, our system is saving component id or tag id into popup settings, and when you duplicate a project, popup settings are still refering to same id, while our system created new ids, since it is completely new (duplicated) project. So you would need to re-apply target in popup settings.
We will work on solving these issues with templates that are using plugins in this way.
Thanks, I figured it after a while. However, I encountered a different issue, where I can’t change the links from the dropdown menu. I opened another topic for that.
same here. is there a tutorial on how to customize the template we bought? its really confusing with this templates. i bought bomba and codify
