Hi, I have been building websites on DivHunt for a few days now, I’m here to share thanks about what you have built, and give my feedback.
Bugs :
- I experienced some of them.
- Builder
- My footer component keeps disappearing, I have to recreate it many times
- I saved many colors in the Styling left panels. Some are working perfectly, other just won’t work (turning into white when selecting them, showing 2 colors names at a time
- CMS :
- Cannot add 2 rich texts fields in a tab in the data model, otherwise the second one doesn’t show
- When I copy paste text, I keep having it pasted twice instead of once
- html links often are pasted inside rich text editors with their tags instead as rendered html links
- It took me a long time to understand that :
- You should double click on CSS properties group on the right side panel. Everywhere else on the web we are single cliking and nothing was mentionned, I thought it wasn’t working and I’d personally perfer a single clic to open/close groups
- you should publish CMS items. The button doesn’t stand out!
Adding and onboarding with tooltips will help avoid these kind of difficulties, and help people undestand a complex platform.
Wishlist
- CMS :
- Multiselect field
- Choosed field to show on the collection list of items. That would allow custom fields to show as checklist (like an Airtable of Notion database) and helps immensely in organization
- Same idea for filtering and grouping posts, based on fields
- Export & / backup all CMS items, inside DivHunt or in external locations like DropBox. If I put all my assets and writing inside DivHunt’s CMS, I need it to be replicated somewhere for security purposes
- Rendering markdown inside the rich text editor too would be greaat
- Please add a button to every rich text editor field to “Full screen”, so it’s comfortable to write there
- In the Rich Text editor, the DELETE key should go to the previous line, when there is no caracter left on the current one. The SUPPR key should bring back the next line, when there is no more caracter left on the current one.
- SHIFT + ALT to move line up and down would be great
- CtRL + X to cut current line would be amazing. I use this all the time (works on Notion and Obsidian)
- Having an option to toggle heading (like on Notion or Obsidian) would change my life for writing inside DivHunt. We can then easily see our outline and navigate quickly. In Obsidian I have CTRL + SHIFT + UP ARROW KEY to collapse all headings. I then see the outline and can go work on another heading section if needed, without having to scroll for 2 minutes to find it
- Builder :
- Button to Duplicate a whole page ? (maybe I can bulk copy paste elements, I didn’t try that)
- Remove / delete element when it’s selected and SUPPR or DELETE keyboard keys are pressed
- Double clic on element in the sidebar tree, to rename the element
- About spacing, padding and margin, I don’t understand that sometimes I can clic on the number and there is a small window with presets that’s very handy. But many times it doesnt show and when I click nothing happens. Why ?
- About the plugins, are they all developped by DivHunt now ? Showing a contact info for each of these would be handy
- Instead of RIGT CLICK + RESET = Double click on the name of the property to reset any value. (some property have the reset options and other don’t. Why?)
Overall, the experience was admirable, efficient and pleasant. Glad I found DivHunt, I’m quitting WordPress
Lastly, could you please explain the diference between Div / Container / Section and when we should use one or the other?
Feel free to reach out to me for additionnal testing or info about the bugs. I can’t wait to see what’s next!
