Page redirected you too many times when change WWW Redirect Rule
try change WWW Redirect Rule to www only then cant open the page builder. not sure if it happened after i change the domain.
Hey, your domain is pointing to two different A records, it needs to be pointing only to Divhunt so theres no conflict.
thank you. the site seem ok now but i cant access the builder
If you go to dashboard.divhunt.com and from there click open builder, does that help?
i manage go to dashboard but i cant open the builder from there
Try like that, you will be asked to login again with that link.
I tried loging through your dashboard, and it worked… Not sure why is it not working for you.
im using google login for divhunt. did i need to create different login?
i just delete the project & create a new project with different name. seems ok now
