Hi, I have created a POST request in the REST API module to create record in AiTable.
From their documentation, here is how the request should look like:
curl -X POST "https://aitable.ai/fusion/v1/datasheets/dstfm9TvQFbnM70AHZ/records?viewId=viwqUaSw1wGgc&fieldKey=name" \
-H "Authorization: Bearer_TOKEN" \
-H "Content-Type: application/json" \
--data '{
"records": [
"fields": {
"Prénom": "Jimmy",
"Nom": "Test",
"email de l'inscrivant": "fan.cat.test@gmail.com",
"Nom de l'établissement": "Test ABC",
"Statut": "Nouvelle inscription"
"fieldKey": "name"
I have defined the endpoint and headers in REST, and following properties:
In the body, JSON format, I have entered:
"records": [
"fields": {
"Nom":"${properties->get('nom')",
"fieldKey": "name"
In the pane with CURL preview, as you can see in screenshot, although I have put quotes in the body, they have disappeared after the value coming from properties, and request is not successful.
I have tried removing quotes in the body and putting them in the properties value, but nothing works.
Any idea why it is wrong?
website: https://step2you.divhunt.website/
