Hello,
I’m trying to check if Flotiq can get integrated using Rest API and it doesn’t look good right now
I don’t know if their API design is good but to get a blog post we need to use the URL: https://api.flotiq.com/api/v1/content/flotiqBlogPost/blogPostId
Thank you for your clear answer!
Will have a look and try it
The only problem as I see is that the URL will have the ID. It might work but it will look ugly as the IDs are “flotiqblogpost-12345567889”.
Will check if I can change that in Flotiq.
