Services Single and SEO of subpages - urgent
I am optimising my website for SEO, especially the meta descriptions, but I stumbled upon one problem. I have all the pages in the left side panel, and I can easily access the SEO for each, but one of my pages has all subpages (these are separate services the business provides), and I don’t know where the meta description is. It looks like this. So, for instance, when I click on the setting when I choose osteoarthritis, write the meta description, and then change the service to poor posture, this will be the SEO meta description for the page “Services Single”, not the osteoarthritis, or any other. My question is how I can optimise these sub-pages with services for SEO by creating
each unique meta description.
These are my services that I can change using drop down menu but have no clue how to access the SEO settings for each.
for single page it shoult be like this
and meta title, description and image are in collections- every have its own.
I used dynamic routes for each service and added custom meta titles and descriptions directly in the SEO settings of those pages. Worked fine for indexing and looks good in search results.
did the same with other page where I created collection with 1000 elements :slight_smile:
I ran into a similar issue before and found that creating separate pages with focused content for each service really helped. It made it easier to fine-tune titles and meta descriptions, which helped my google business seo too. Search engines picked up each page better, and they started ranking for more specific keywords. Linking between the pages also gave them a bit more boost.
I’d set meta descriptions on each service subpage itself, not on the main services page. In Divhunt, I usually create separate dynamic fields for each service so every item in the collection gets its own meta title and description. That way switching between osteoarthritis and poor posture won’t overwrite anything. If you want an example of clean structuring, I like how https://luckybrand.cz handles its service pages.
