Is there option to add the link to the span?
Hey @petrbilek
Here’s a video tutorial for easier following:
There’s a feature in Divhunt to swap HTML Tag on the right click
Let’s say you want to convert the Word “level” to link
Step 1
Add 3 spans
Step 2
Select the span you want to convert to a link and right-click on the Link Tag
This is a bit of a workaround until we build a more intuitive UI solution for this.
Hope this helps!
Ahh never thought I can change it via clicking on the top panel. Thank you. Now is all clear.
You can also use Rich Text element inside builder to achieve similar effect, but might be just easier for you.
Only downside of this is that styling using designer is bit harder on rich text elements, but it’s possible using custom selector:
The first way is ok, thanks!
