If I create any page in Divhunt, the status code is always 404 although the page shows fine…
That’s only when you are logged in as an admin, because there’s no caching enabled for you, and our server throws that error.
If you check from incognito after you publish a website, you will not get that error.
Same works for search engines, they will not see this error
Ok, good to know, thanks
