You need to use Embed in this case in order to render HTML, so just convert that element (is it Div or P?) to Embed, select it then from navbar find embed and right click on it.
Hello @dejan and thanks !
yes, however, I still have some hard times
BoldItalic works for example fine (when extracted from strapi and rendered through Divhunt) but I sill have problems, such as
spaces between paragraphs which are in the same “Rich text Markdown” zone.
Would you point me to which Markdown syntax is available when going through the Divhunt rendering ?
