I can upload images. The images show, I can use it in builder as well, copied links work. But when I want to add it again (let’s say it’s an icon) the picture cannot be found, it simply doesn’t show in the popup browser window. But the link to it still works.
I’m using Edge, cleared all Divhunt related cache, tried another project, private/incognito window and in another browser - Chrome. Same problem.
I’ve done some more trial and error and noticed that lower resolution images does work. I’m trying to find the breakpoint - if there is anyone
Just to clarify this, we figured out it’s up to the problem of uploading the same image twice. If the image contains the same metadata, it will read it as the completely same image and generate the same upload link, which causes the problem of the image disappearing from Media Manager.
If you just want to use the icon again (and know the name of the file you uploaded), you can search for it so you won’t upload it again.
Alternatively, if you want to lead up different resolutions of the same phone, a simple workaround for now is to change the file name. I believe this should be enough to have it show up again :).
Hi!
I just uploaded 16 photos, all showed, I used one photo in the grid, then when I’m about the add the second one - all is gone. Renamed them all before upload.
Fixed, please test. Might still be a bit buggy, but should do the work. I don’t want spend much time since new Storage application will come in future with folders and much more options etc.
@dejan
I tried different uploads styles and it works now!
If I upload the same image, it will show as two, and when I open the box again to attach the same image again, it only shows one. I just assume that it recognize the size and name of it and remove one of the duplicates. In wordpress it just adds -# to the file. I.ex photo.jpg, photo-1.jpg, photo-2.jpg etc if you upload a file with the same filename.
But now I can adds files and they don’t disappear!
We never double upload same image, we always check the content and size to compare if image is already uploaded, that’s why there was some issues with it.
In this way, we save space by not uploading same images multiple times.
This is so weird. Now when I uploaded 16 images they showed as usual at initial upload, but my “use” button told me I had 21 images selected, de-selected all I could see, still 5 selected. So I closed the window, open it again - all 16 images gone This is in the CMS when I try to add multiple images into the “Wedding Info” item I have there.
