Not sure the fastest way to get help, but my site having this issue!
using airtable to populate
Hi @btcjon
I have looked just from curiosity and I couldn’t see the problem.
Which eCommerce services are you using in your shop?
I think I fixed by reconnecting Airtable key and had to re-map many things. Note: if you add fields to airtable it can screw up your site.
Thanks for sharing this, we have implemented the fixes, should be all good now even if you modify the Airtable.
If it is not a secret, would it be great if you can share how you do your e-commerce system with Divhunt?
