carissa
September 28, 2023, 8:45am
1
Hello there,
So I published my blog on the website yesterday.
When you open the homepage and then go to the blog section, everything looks fine.
However, when a visitor attempts to open the blog page using the url https://upgradingwomen.com/blog/single-post/unveiling-the-power-of-branding-apples-epic-partnership-with-olivia-rodrigo , the page does not open. It displays a white screen.
Could you assist me with this problem?
dejan
September 28, 2023, 1:30pm
2
@carissa
Seems like the slug of blog is different:
This is the one in Collections
unveiling-the-power-of-branding-apple-s-epic-partnership-with-olivia-rodrigo
While this is the one you are trying to open
So if you try to open with the correct slug, it works:
https://upgradingwomen.com/blog/single-post/unveiling-the-power-of-branding-apple-s-epic-partnership-with-olivia-rodrigo
What you can do?
Manually modify the slug in Collections to fix the issue:
However, there’s also a small bug on our end if the slug is not correct. Thanks for reporting that.
carissa
September 28, 2023, 1:54pm
3
btw, a few days ago, I created a new website using the same template as the main website I use. which I duplicate. Is it possible that is causing the white screen page?
because I see on my new website that the blog site is updated with the new blog that I just uploaded to the main website.
dejan
September 28, 2023, 2:09pm
4
@carissa
Each project works individually for itself. There can’t be any conflicts. The white screen error in particular seems to be a bug on our end which happens once the slug is not correct or doesn’t exist.
We will fix that, thanks for reporting.
carissa
September 29, 2023, 7:17am
5
Hi @dejan
Have you fixed the issue?
Because the white screen still appears
dejan
September 29, 2023, 2:09pm
6
@carissa
It’s fixed. Works now.
I’ve created 404 page with simple text, but you should style it, so in case users go into wrong url, they will see 404 page.
carissa
September 29, 2023, 2:20pm
7
Great, Thanks!
I really appreciate it.
