Hello
Unfortunately this is an open-ended question, so I apologise in advance.
I have added text in the Hero section and I want it to be the centre of attention. Would you have any suggestions? I can’t see any options for it to change or modify when I hover over it; I can’t find any hover events. So my questions are:
Is there a hover event for text?
What cool stuff can you do to the text? Either when the move hovers over or its left idle.
Is there a way to embed an image within the font lettering and when you hover over it, it slightly tilts and moves as if you are peeking into a keyhole?
Is there any other cool stuff that anyone can recommend for text/font hero sections?
Context: The site is for a music band. The theme is edgey / mysterious .
Thank you @Pakic . Please note that its not perfect! I’ve been experimenting with Rive.app (thats the text currently in the header that I can’t seem to place in the Hero section)
Since I’ve asked the questions, I’ve been looking at these & don’t know if they are possible Fluid text hover (codepen.io) Repellers (codepen.io) (cool) text effect (codepen.io)
However, I’d like to see if Divhunt features could do the heavy lifting rather than having to try to embed some of these in (as I can’t properly remember how to code)
That last example is quite easy, but currently we dont allow gif images, so you can’t upload one. We will approve that in future, for now my suggestion is to use regular image + tilt animation to make it a bit entertaining. Here’s a video tutorial on how to do that:
And here’s a full video tutorial for Tilt plugin that I showed you in video above:
Hey @Pakic
I smiled all the way through that video. You read my mind. I initially tried (I’m not going to admit how long, but its definitely more than a few hours) to pull off this exact feature and failed. I particularly liked the glare effect in the tilt.js tutorial. I’ll implement this all today.
Thanks so much for your help. Keep up the good work
Much appreciated
David
