Hello, how to make 404 page?
We don’t have 404 page still. Will let you know once that’s implemented.
Hello @dejan,
Firstly, I’d like to express my gratitude for your efforts. Using Divhunt is truly a delightful experience.
I understand that the 404 page is not yet in place. However, I was wondering if you have an estimated time of arrival for when this feature will be available. For me this is a quick win that will also benefits your main website from a SEO perspective.
Thank you in advance for your response.
Any update on this? This is a SEO requirement on my side. Thanks! ![]()
@petrbilek @mxcrml @Rajat_Subhra
This feature is online now, right click on page > Set it as not found page, then publish your website and it should work for your visitors.
This is cool. Finally updated
I have done enabled. It works. Thanks @dejan
@ric From tomorrow you’ll see change-logs/updates inside your builder, so every new thing we do, you’ll see it there
Amazing, thanks. Nice update
How or when do I need to use this 404 page?
I understand that is “page not found” right?
Why is it important to SEO?
@dejan
This is perfect, thank you so much !
Yes, you are correct. A 404 page is commonly referred to as a “page not found” error page. Having a customized 404 page is important for SEO because it helps :
- Improve the user experience on your website : When a user encounters a 404 error, they might feel frustrated and leave your site. However, with a well-designed 404 page, you can provide helpful information, navigation links, or even suggest relevant content.
- This can encourage users to stay on your website and continue browsing, reducing the bounce rate and improving overall user engagement – and SEO.
Hope this helps.
Now I get it
It is very important yes
Thanks a lot for your reply ![]()
Where in the builder can we find the change logs/updates?
maybe it helps to track this issue here. ![]()
This Option isn’t available anymore in the builder…
but maybe it’s better, to create anyway always a 404 page for a new project.
We temporarily removed that feature due to some bugs, we are currently working on it and it should be available for use very soon.
It’s fixed, please allow 1-2h in order to get update live.
Sorry for this delay, next time I’ll fix bugs like this super fast, just this time I was swamped with several things that had to be done.
may i know if the 404 page is working?
Check from incognito tab
nice, thank you for the info
