Hey, might be helpful for you if you will need a redirect after form submission.
Just set-up a new js code in code library.
mdEvents.Fn('catch', 'forms.success', function(data)
/* If you have multiple forms, check the id of form to match */
if(data.form.id !== 99) { return; }
window.location.href = '/diky';
@petrbilek Hi Petr, would you mind helping me out? I also want to make a redirect. Can you explain more about how to insert this code and what to edit? I am not that familiar with code and it seems that you are quite an expert. I want the form to redirect to mydomain.com/nearlydone.
Or can the “Action” URL be used as redirect? Didn’t find any info on that.
