dejan
March 17, 2024, 10:20am
41
@nocodecosmos
Iâve migrated them, please be advised once you finish your website, youâll need to point your domain to the following IP: 128.140.102.47
Most likely by then we will have a new dashboard ready with all those info, but just in case.
Also let me know if something doesnât work as intended, still new feature and youâre the first one to test it
Hi @dejan ,
first ⌠it works. But i found some Issues with the builder.
i pointed the domain an the i get a white screen, after refresh i get this screen:
after next refresh the builder opends.
In the builder i get this error message:
Next problem is, if ei publish i get this screen:
Thank you
dejan
March 25, 2024, 6:21pm
43
@nocodecosmos
Thanks for reporting issues, and I already knew :), I can see all the errors happening in Divhunt in real time
I am working on it, and will be fixed in a couple of hours. There are some problems with Database connection since multiple servers are being used and Postgre canât manage pool connections properly. Working on it will be done soon.
dejan
March 26, 2024, 1:11am
44
@nocodecosmos
It works now properly, I still need to do more work on this, but it shouldnât break again and you wonât notice anything.
@dejan
Tank you so much. I noticed that the collaborators features didnât work. I canât invite a collaborator to the EU project
And the second one: I want to active a license on the project, but this is not enabled. When it is possible?
dejan
March 26, 2024, 9:25am
46
@nocodecosmos
For now you can use Divhunt without license, everything will work fine. We will release new billing system and then youâll be able to do so.
Itâs is possible to remove the [build in divhunt] label? Its important for the client projects.
Thanks ⌠any updates about the âAdding collaboratorsâ Problem?
Hi @dejan any Information about that?
Adding collaborators is not possible.
dejan
April 11, 2024, 10:51pm
51
@nocodecosmos
Does it say any error? Will check tomorrow, was bit busy
@dejan sorry there is no error message.
@dejan if got an issue with the project-id: 9405
Error Message: There was error trying to validate site. Please contact support.
